EZ Loader Trailer
paboater
I have single axle trailer for my 20 foot SeaSwirl. It does not have trailer breaks, I am wondering if there is a kit to buy that would allow you to put them on the trailer? Thanks in advance for any help.
Re: EZ Loader Trailer
If your Axle has the seat,+ bolt holes for brakes,<br />Yes......<br />If Not,<br />You'll need to replace the Axles also......
paboater
What do you mean the seat? I look at the axle today and it has 4 holes on the axle right inside where the tire attaches to the hub.
Boatist
Paboater<br />The axel has to have a place to bolt on the backing plate for drums or the caliper support for disk. check the link below they have kits and do a good job of letting you know what you need. They help me alot before I decided to change form drum to disk breaks. One thing I liked was they told me tie down was having a problem with their disk and reccommended I wait 3 month if I could for them to resove the problem. Also gave my a contact at Tie Down to call to find out what the problem was and when they would come out with the improver breaks.<br /><br />Anyway they treated me right and were a big help.<br /><br /> http://www.championtrailers.com/techsup.html#articleindex
paboater
Thanks this is exactly what I have been looking for. I have those four holes on my axle so that means it should be compatible right?
paboater
How do I know if I need the 10 inch kit or the 12 inch kit?
Boatist
paboater<br />My 21 foot Aluminum Runabout has 10 inch disc and they work fine.
paboater
So it is just a matter of preference and it is up to me which i choose?
