f50tlrz hard starting
muskrat
Carbs were cleaned motor is hard to start once started idles great & turn up fine.Compression ok spark ok..Thanks
99yam40
Re: f50tlrz hard starting
did you follow the service manual setting the carbs back up after reinstalling?
did you clean the prime start system/passages also and make sure it all works properly?
