Fat Fifty... Any advice?
Joe Reeves
Re: Fat Fifty... Any advice?
The old 1958/59 50hp was a outstanding engine in its day... the first ever V4 design, and was the steping stone up to the V4 75hp model and others that exist to this day.
For those that are unaware..... The synchronization on the 1958/59 50hp models that exists between the magneto and the carburetor is different than the settings that pertain to the 1960 75hp and later models.
Setting the synchronization of a 50hp V4 as per a 75hp manual or vice versa will result in a waste of fuel. No, I don't have the 50hp manual here with me any longer and my memory is somewhat failing so I can't explain the difference... you'll have to look it up.
The carburetor setting is pretty fussy also... a 1/8 turn too much can waste a good bit of fuel, even on the 75hp model. The proper way to set the carburetor follows.
(Carburetor Adjustments - Older V/4 Downdraft Carb)
(J. Reeves)
NOTE: The early model downdraft carburetors incorporated "Adjustable High Speed Jets". The later model downdraft carburetors used "Fixed High Speed Jets". The high speed jets would be located in back of the two bottom drain screws. Follow the below instructions accordingly.
NOTE: If you do not have adjustable high speed jets, ignore those paragraphs pertaining to same...... BUT do make sure that you manually inspect and clean the two brass fixed high speed jets which would be located in back of the two 7/16" slotted hex head bolts in the bottom front portion of the float chamber.
Lift the center High Speed Control lever and turn it so that the point faces forward, resting on the high ridge. This will disengage the lever control gear from the individual high speed jets (slots). Have the slow speed needle valve knobs installed upside down so that they can be turned without encountering any obstruction.
Gently seat each of the High Speed needle valves, then back each one out one (1) turn. Gently seat each of the Slow Speed needle valves, then back each one out one and one half (1-1/2) turns. NOTE... have the jam nut on the s/speed needles snug so that vibration won't have any effect on them, but loose enough so that you can turn them without a great amount of effort.
(High Speed)
With a reliable person at the wheel, and one kneeling in front of the engine, start the engine (yes, it will run lousy with the above initial needle valve settings), put it into forward gear, and apply full throttle. Start with the High Speed adjustment on the left using a screwdriver that properly fits the slot.
(High Speed Adjustments)
At full throttle, with the proper size screwdriver, slowly start turning one of the H/S needles in segments of 1/8 turn, waiting momentarily for the engine to respond, then repeat turning. You will reach a point where the engine will start to die out. At that point, back that needle valve out approximately 1/4 turn. Now, go to the other High Speed needle valve and repeat that procedure. At some point in that 1/4 turn out, you will find the smoothest high speed setting (you can now lower the throttle rpm). That will have both high speed needle valves set correctly, and at that point you can lift that center lever adjustment of that high ridge, keeping it lifted until the point is facing the engine, then lower it into its proper position. (When you turn that lever now, you're adjusting both High Speed needle valves at the same time.)
(Slow Speed Adjustments)
Now, lowering the rpms of course, take the engine out of gear and set the throttle just to where the engine will stay running. Again, in segments of 1/8 turn, slowly start turning in one of the slow speed needle valves, waiting a few seconds between each turning for the engine to respond. As you turn the s/speed needles in, the rpms will increase..... and as it does, lower the rpms to where the engine will just stay running (otherwise the rpms will climb quite high). You will reach a point whereas the engine will either start to die out or it will spit back (sounds like a mild backfire). At that point, back the needle valve out 1/4 turn. Repeat the process with the remaining slow speed needle. Again, at some point in that 1/4 turn out, you will find the smoothest setting. When finished, tighten the jam nut somewhat, then remove and reinstall the s/speed knobs correctly (right side up).
Erik.C.
I'm looking forward to spring and having my motor running well enough to try the carb adjustment procedure. Thanks Joe.
59 Fatty
Thanks Joe! I am looking forward to the same thing as Erik. I have had mine running on the trailer, but I'm sure that setting everything so it runs well is best done under load on plane and the wind rushing by. Combined with the blue smoke and gas smells, it doesn't get much better than that. I wish I could bottle that, lol.
Erik.C.
Great cologne idea. I'll bet you could sell it here! :laugh:
Erik.C.
That video is before you did all work to the hood, right? It's hard to tell from the video. Sounds pretty good though to me.
jbcurt00
Might keep the skeeters at bay, but it will probably attract a lot of iboat's 2cyl OB types that'll drink all your beer. Not sure that's a win~win :facepalm:
59 Fatty
Yeah, before hood redo. After that vid was shot, I decided to keep this motor and make it a permanent team.20131124_180312.jpgThis is where the rest of the engine is hibernating for the "winter". I'm putting the hood back on and snappin a few pix of my big girl in the sun wearing her new top. That conjures up some weird pictures in my mind. LOL hahaha
Erik.C.
It kinda gave me a few weird thoughts too. lol. :facepalm:
