Fiberglass boat in saltwater????
jacobmorin
I am going to be putting my 15' fiberglass boat in saltwater for the season this year. I have been advised to use bottom paint on my boat. Can anyone point me in the right direction for:
1) a good brand?
2) should I use a brush or roller?
3) How many coats do I need if this is the first bottom paint the boat has seen?
4) Should I wax, use rubbing compound, or sand the boat before I apply the paint?
5) How many times should a boat be painted in a season or should it be done every couple of years. Please remember that I will have it in salt water in NJ.
Thanks!
tashasdaddy
Re: Fiberglass boat in saltwater????
follow the directions of each manuf. google them, and search out instructions. the best thing you can do in salt water is use it alot.
Yacht Dr.
jacob, are you Keeping the boat in the water ? or just launching it for the day ?
IF you do plan on leaving it in the water..then I suggest you use an Interlux product called Interprotect 2000. Its a barrier coating system that will prevent blistering and such..
After you Interprotect then use Interlux's VC17 IMO.. its thin and you only have to put one coat on a year..with minimal prep. ( proper prep for Interprotect is 80g paper )
You can coat right over Interprotect with VC within its window .. without having to sand..
YD
If it is a fairly new boat and on a trailer at the end of a day...... use nothing.
If you intend to dock it or leave it floating for the summer follow up whatever paint you use with a good monitoring of the bottom. Look for growth and claen as needed. If you want to use paint follow the directions.
