fiberglass filler
Ironside
Hello again what do you all think of using longhair fiberglass filler to lay floor in,I am thinking of using it around the edge of the floor were it meets the hull and inbetween sheets of ply or anywere else there may be space to fill. Is it strong enough and will it adhere to the hull if my prep work is good and is durability adiquate .Sorry about the spelling my 2 fingers i type with sometimes miss there mark Thanks
Re: fiberglass filler
If you're using Polyester resin,+ Not Epoxy,......<br />It'll work just Fine.......
Ironside
Thanks bondo im working on an incredibly tight budget so any alternitives that will still give me a boat fot the next five or more years are appreciated
