Fiberglass repair? Keel Patch
McBoatin
Hi i bought a 1978 Sea Sprite a 16ft open bow ski/fish tri hull. The hull in general is in good shape. It does have a 6inch area on the keel that is damaged/crushed from where the keel hits shore. It seems that the damage has reached the wooden keel of the boat as I think it is wood i see.
my ? is: should i just sand away the damaged area before I fiberglass or should I take a chisel and take out the damage?
Also any tips on the fiberglass repair. last time i did it was with my dad 10yrs ago on a canoe.
i just purchased a fiberglass repair kit from the auto store. will that do?
Woodonglass
Re: Fiberglass repair? Keel Patch
Welcome to iBoats!
If you want us to be able to accurately diagnose your problem and guide you to a successful resolution you should provide us with some pictures of the problem. It is almost impossible to tell you how to proceed with just a verbal description of the problem. Your approach seems to be sound but pictures will tell the tale.
