finding info on model and HP of my 350
dasboata
hi can someone provide me a link where I can search model and SR numbers , I know I have seen it before but can not find it now my model # is 807447A14 thanks Chris
Fun Times
807447A14 = 350 Remanufactured Partially Dressed Plus-Series Crate Engine
Application Alpha 275 hp @ 4800 RPM, for MerCrusier Alpha and Volvo SX applications. Features high flow Gen+ iron heads, roller camshaft, 750cfm, 4-bbl carburetor, mechanical fuel pump, Thunderbolt V ignition with knock control, stainless steel valves, Hypereutectic pistons, high flow oil pump, water pump, harmonic balancer, oil pan, engine harness and flywheel. Operates on 87 octane fuel.This new engine is a power solution for MerCrusier Alpha and Volvo sterndrive applications
SKU: 714-807447A14
Alternate SKU: 714-807447A14
Category: Engine>Quicksilver Remanufacturing & Returns
https://www.**************/mercury-qu...-807447a14.htm
If the link don't work then just search the model number online...That's where the info above came from.;)
If you're looking for a parts catalog then this should be it,https://www.mercruiserparts.com/350-alpha-4-bbl-crate-engine-all-u
Here's the list to choose from if not it above, https://www.mercruiserparts.com/parts-for-mercury-remanufacturing-produc
dasboata
SKU: 714-807447A14
https://www.**************/mercury-q...-807447a14.htm
I looked like crazy I did have the 714 # in there thanks again Chris !!!!!!!!!!
TyeeMan
I have a Mercury Remanufacturing Plus Series 5.7. Mine also has a new starter and alternator with serpentine belt. Actually it's a 5.8L, 357 cubic inches, it's bored .040"over.
If you look on the block down by the starter you will see a tag (should be there) with the info. If you're real curious you can call Mercruiser with the info on the tag and they can tell you what boat it came out of and likely who installed it in your boat as it's likely been installed at a certified Merc dealer.
The dealer I bought the boat from new nothing of the engine, they didn't install it. Very long story very short, I took the info off the block and called Merc. They told me what boat the engine originated from, they were pretty close in getting what kind of boat (my boat) the engine is currently in and who installed it. I called that dealer out of curiosity and they verified it.
Had the dealer that sold the boat known anything about this engine they could have gotten at least another 4-6k for the boat. Good thing for me they didn't know anything. :D
Freaking awesome engine though!!! Makes wonderful power with 2 or 7 adults in the boat. I was lucky enough to get the boat slightly after the engine break in period.
And if you haven't figured it out already, DO NOT PUMP THE THROTTLE TO START COLD OR HOT. Just crank till it starts. Not knowing that, the first couple starts I flooded that thing so bad it wasn't funny.
QBhoy
Maybe worth remembering that with these reman or after market engines. Their quoted power output depends on the carb.
I have a friend that replaced his 5.7 2 barrel carb with one quoting something like 280hp on the write up. Engine came undressed and bare. Obviously he used his old ancillaries and carb. There was no noticeable difference over the old 250hp 5.7 and much disappointment.
All as a result of him using his 2 barrel carb and manifold. I’d imagine the wonder hp figures were maybe seen with at least a 4 barrel or FI and perhaps even measured at the the flywheel too.
TyeeMan
The Mercury Remanufacturing Plus Series engines come with a new dual plane intake manifold and 750cfm 4 barrel.
Coming from Mercruiser, , not really aftermarket like Engines R Us or whatever aftermarket engine rebuilder.
