Fire in the hole.
Captianloud
Well, I've done it, the transom repaired the engine in. Took the day off work today and made all the final connections and after fiddling with the distributor just a little bit, my automotive 4.3 fired right up. I'll post some pics on my site about this shortly. I think I'll test run it tomorrow.<br /><br />Here is the site I did.<br /><br /> http://users.adelphia.net/~chrisradvanyi/ <br /><br />Here are the threads from the past that relate to this <br /> http://forums.iboats.com/cgi-bin/ubb/ultimatebb.cgi?ubb=get_topic;f=24;t=015589#000000 <br /><br /> http://forums.iboats.com/cgi-bin/ubb/ultimatebb.cgi?ubb=get_topic;f=24;t=015570#000000 <br /><br /> http://forums.iboats.com/cgi-bin/ubb/ultimatebb.cgi?ubb=get_topic;f=24;t=015449#000000
Captianloud
Re: Fire in the hole.
BTW I used the marine flywheel with the automotive balancer.
Boomyal
Great pics Captianloud. Love that yellow engine. Hope you painted your bilge to show it off.
I have this feeling you are going to be looking for a different oil pan soon. The one in the picture below is going to hit the bottom of the bilge before you get the engine down on the mounts.<br /><br />Removed picture, WAYYYYY to big.<br /><br />Click on the link below to view it.<br /> http://users.adelphia.net/~chrisradvanyi/index_files/DSCF0595.jpg
KnottyBuoyz
Missin' a couple 'o cylinders ain't it? *wink*
RubberFrog
Did you build custom engine mounts while you were redoing the transom?
Bt Doctur
Unless its an optical illusion,the pan looks a bit too deep to fit.
Ayuh,..........<br />Unless of course,... Captianloud's Raised the X dimension by,... Ohh,.. 5 or 6 Inches.......... :D <br /><br /><br />The Pictures are just alittle Large Too......<br /><br />Maybe that's why All 3 times I've tried to visit Captianloud's website,........<br />My 'Puter Locks Up,+ Needs a Reboot..............
Captianloud
That IS the Mercruiser oil pan. It was identical to the Chevy oil pan except that the auto version was more rusty.<br />I'll post a pic of the installed engine post alignment on the site. <br /><br />THe pics on the site are all around the 200K range in size but I think there are 18 of them.
Not Doubting you,.. At All.......<br /><br />But,.. Man,.... It Looks like an 8 Qt.er.......<br /><br />Must be an Optical Delusion......................... :D
Captianloud
Actually the long block looked small until all the accessories went in.
Cptkid570
Ensign
Captainloud -- I saw where you got the engine for $65... How much do you have in it now that the machine shop did their part, and you bought the new parts for it???
