firing order and cylinder location
Status
Not open for further replies.
stratos150xp
I have an 88 evinrude 150xp, e150stlcca, what is the firing order for this motor as well as the cylinder arrangement? Thanks...
79Jimmy
Re: firing order and cylinder location
If its anything like my '86 150HP then its just 1-2-3-4-5-6 with the port bank being 2-4-6 starting at the top and the starboard side being 1-3-5.
My '98 Johnny 150HPV6 has the same firing order. 1-2-3-4-5-6
boobie
They're all the same be it V-4 or V-6.
As long as they are 60* V motors, right Boobie?
boobie
No. Both 60* and 90* are the same. If you know something different post it back.
Gee, My 90* Fat Fifty was not 1-2-3-4. (1-4-2-3??)
I thought the 60*V motors could fire smoothly in order, since cylinders are 60* apart. 90*V motors fire every 60* as well, but cylinders are 90* apart vs 60* apart.
boobie
Are you sure about the Fat Fifty ?? Yeah, I know it had a magneto. Check some newer BRP service manuals on the 90* motors and see what they say.
boobie
I just checked around and the opinions I got the firing order on the Fat Fifty was 1-2-3-4.
Surprising. Although I have no clear memory, I did not think it was that. The distributor cap had the numbers of the cylinders molded into it, so you could not mess it up easily. I guess I never looked close.....
yanto106
i have got a mariner 150hp 2 stroke what would the firing order be on mine please.
GA_Boater
Start a new thread in the correct section. You have a Mariner, not a Johnson or Evinrude.
Closed.
Status
