First boat! Need help with ID/ suggestions
Mcj450
Hello everyone I've been reading these forums for quite a while and I am thoroughly impressed with the wealth of knowledge I have found!
I have recently run across a small boat that I could not resist buying at the price I payed for it, however being as impulsive as I am I know little about it Other than it floats and a 4hp motor does not try to pass the boat when I floor it!
Does anyone recognize the unreadable crest on the bow cap?
What size motor could this boat handle if the transom was fixed up a bit?
Weight capacity?
any modifications to make her a little bit stiffer? ie stringers or such
Currently using a 1978 Johnson 4hp weedless drive which is running like a top thanks to this forum!
However I still cannot get on plane!
I wouldn't run any more than a 6 hp on it.
any modifications to make her a little bit stiffer? ie stringers or such ???
Yes, put the wooden bench seats back into it.
Mcj450
Oh yes the benches will be going back in
The ones that were in there kept leaving splinters in bad places
Would Baltic birch plywood be suitable for this?
I have lots of it and have always been happy with it in other applications
