Fisher Avenger SC 14
Dadicus
I have an elderly neighbor who purchased a 2007 Fisher Avenger SC, 14 footer last year. It has a Merc 40 hp. It's a nice looking boat, and good for what he does (mostly reservoir fish), but he's complaining of a problem. He says the boat seems to fill with water too easily. He says that after an hour or two of fishing there's enough water that the bilge pump can't keep up with it. He's worried that most of the water may be coming over the transom. I have not ridden with him to see the problem for myself, but he's a handy fellow and fairly knowledgeable about boats, so I trust that he's probably right. Have any of you heard of similar problems? Is the 40 horse too big for that boat?
tashasdaddy
Re: Fisher Avenger SC 14
it actually sounds like he has a leak some where. common, is the drain plug. recommend the twist type rubber drain plug. http://www.iboats.com/Twist_Drain_P...z.54343--**********.130625455--view_id.470214
if his boat is like the picture, he definitely needs a bilge pump. any water over the transom, should go into the splash well and drain immediately. he also could be stopping so fast that the water in the splash well is leaking into the bilge thru the control seals.
specs, for boat.Length 14' 3''
Beam 74"
Depth Inside 19"
Bottom Width 60"
Max. Recommended HP 40 HP
Max. Person Capacity 4 Persons
Max. Person Weight 600 Lbs.
Max. Weight Capacity 1020 Lbs.
Hull Material 0.090 5052 Marine Alloy
Weight (approx.) 640 Lbs.
Fuel Capacity 6 Gallons
Package Length 19'
I had a Fisher boat and found a few leaks.... I used gluvit on the seams and had to re-seal the live well ports and hoses. Great boats but not maintenance free ;)
marquette
if it was a new boat i would look for a loose livewell hose or unsealed mounting bolt on the motor. as much as it sounds like it is leaking a missing rivet or bad seam should be pretty easy to find with a hose or visual inspection.
