fitting a deck from scratch??? newbie HELPPPP!!!!!
Wadgelet
Hi all i was recently given a boat but the deck and stringers had been stripped and removed. transom too. i have fitted a new transom and trying to work out how to get a height for my new stringers and so on to ensure the deck is level when on the water. there are no marks on the side of the boat of where the deck used to be as they used a grinder and sanding disk to clean up the edges.
Grub54891
What brand and year of boat? There are many things to consider as in a fuel tank height or other components under the deck. Have any pics?
Wadgelet
hi it is a small 3m cathedral hull. not sure the age or the make. i am from south africa
Woodonglass
Yup post some pics of the inside and outside of the hull and we'll be able to guide you
