Fix up the single or go for a tandem?
BTL
Recently purchased a 1989 Wellcraft 18 sport Center Console as a project boat. It came with a single axle trailer that needs work, but before I invest $400-500 into overhauling that one, I'm wondering if I should just buy a tandem axle trailer for it instead.
Gross weight of the boat and trailer is 2900lbs (according to the title). Would you be comfortable hauling that on a single axle?
Sorry if this is a stupid question but this is by far the heaviest boat I've owned.
ahicks
Many of us haul our boats twice a season, for a total of 20 miles or less (often much less). If you're going to be one of those, a trailer like that might work fine, as long as it's capable of supporting the boat properly. If you plan on a LOT of trailering, you might want a little more trailer than that, especially if you're planning on loading it up with a bunch of "stuff" when on the road...
BTL
Thanks. Most of my trailering with this boat will be at least 2 hours each way, maybe 4-5 times a year. I've been looking at tandem axle trailers online but it seems like most of them are made for boats that are 22' or more.
Alumarine
I would be comfortable hauling 2900-3500 (including trailer) lbs with a trailer in good condition rated for 3500 lbs with good bearings and tires.
Tandems tow real nice, but are almost impossible to move around by hand. If you want to upgrade but stay with a single axle, EZLoader makes a 3700lb single
Sprig
If you don't really need a tandem stick with the single. For your size and weight boat you are fine with the single axle. I don't see any advantage in your case going to a tandem. Also as someone already pointed out they are near impossible with a boat on to push around by hand. Then of course you have 4 tires to replace and 4 sets of bearings to deal with. You'll be just fine with a single axel.
Plus with 2 axles you are often required to have brakes on both of them
BTL
Really appreciate the advice guys. I was planning to put new everything on this trailer so I guess I should be good. Thanks.
Lou C
Keep in mind if you are up grading the single you can get a heavier duty axle & spring to match (ie 5200 lb 6 lug hub vs 3500 5 lug hub). This allows you to go from 10" to 12" brakes, 15" rims and tires that can be had in a 'D' load rating. While this doesn't increase the capacity of the trailer, it does give you a nice margin of safety in terms of the load capacity of the springs, axle, tires and brakes. I would not worry about a boat that size on a single. You can always carry 2 spares lol....
BTL
The current axle is a 3500, in pretty good shape. That's not a bad idea though since I'm already replacing pretty much everything else.
