Fixed - moisture in valve covers, milkshake in breathers.
Kevlar7R
There are a lot of threads about water intrusion, and milkshake coming out of the breathers, however I hadn't found one that covered my exact problem. I solved mine, so I thought I'd share my experience in case others are in the same situation.
In my case, I was getting the oil/water mix milkshake out of my breathers, but had no evidence of water in the oil pan. The engine ran perfect, no evidence of anything wrong. I was about to strip the motor down to the block, and look for the problem.
The fact that there was no water in the oil pan was what really had me scratching my head.
So, I get to drinking a beer with my neighbor, who's been elbow deep in engines and grease his whole 70+ years. And he asks me what my engine temperature is. It was then that it hit me, that I'd never seen the engine over 130 degrees. He deduces that my thermostat is stuck open, and the engine isn't running hot enough to vaporize the crankcase gasses and they are condensing in the valve cover.
Turns out, he was right. My thermostat was so corroded I had to hammer it out. New thermostat, the motor now holds 160 degrees, and runs 180 degrees at full throttle. After 2 days on the lake, and running 45 gallons of fuel through the boat, there is no milkshake. I'll be damned that crazy old guy solved it for me!
So, if you're getting water at the breathers, but not in the oil pan.... Check your thermostat!
MarkSee
Re: Fixed - moisture in valve covers, milkshake in breathers.
Hence why it is a fact, not just a clothing line:
OLD GUYS RULE !!!!
Mark
OLD GUYS RULE !!!!
Mark
Ayuh,... Gotta agree with That,.... :D :D
littlebookworm
You can't top experience. Computors may have changed how engines run, but they still haven't changed the basics, and the older guys (I guess I'm included) have seen and done quite a bit with them. Enjoy your boat. Hy
Kevlar7R
My boat is an 87, with a the merc 350 i/o, so no computer. A computer might have pointed out that temp was too low....but then again, I should have made the connection too.
When he mentioned it, I looked at him like had 3 eyes (Course, a lot of his stories elicit the same response). I decided I was going to check the thermostat in conjunction with stripping the top end of the motor. Once I got a valve cover off (harder I i thought, had to remove exhaust riser and throttle linkage to get it out) i noticed there really was a tiny amount of milkshake in there, it was just concentrated on the breather where I could see it. That's when I decided to pull off the thermostat. Put it together and fired it up in the driveway, and watched as the amount of milkshake in the breather tube started getting smaller. Then decided to go to the lake!
