Flaking paint on aluminium
leoo24
Hey guys,
the paint on my windshield frame is flaking off, i don't know if it's the original paint or that it had been painted at a later date, i bought the bought second hand.
Underneath the flaking paint the aluminium seems pitted and white, i did try aluminium cleaner on a section and it does clean it up, not mirror sparkling but the ptting ofcourse remains, it's not massive pitting but noticeable to me.
Do i repaint?
cheers guys
Leo
Re: Flaking paint on aluminium
Ayuh,... I would Guess it's the anodizing peeling off....
With proper prep it might hold paint...
Yacht Dr.
I would remove the shield... scrape off as much peeling paint you can.
Next is sand blast it ( small cheapo blaster would do fine ).
Then all at one time.. Alumiprep,Alodine and Zinc chromate prime. Like this..
http://forums.iboats.com/showthread.php?t=457159
Then fill all the pinholes with some acrylic putty with a razor blade.
Reprep/fair.. and reprime ( I like the 2 part epoxy primer ). Let that cure then reprep w/320 grit and paint with a good 2 part paint ( or some auto repair suppliers can sell you a good 1 part flake paint in a rattle can ).
Reinstall.
There are other ways but this is how I would do it.
YD.
leoo24
many thanks :)
that'll be a decent all weekend project for me.
