flex seal
scouser5
Forgive me for asking this question but has anyone use that FLEX SEAL on a fibreglass boat ???????? :confused:
matt167
Re: flex seal
For What? It is basically rubberized undercoating FWIW
jigngrub
Re: flex seal
I consider that stuff a very temporary band-aid.
If you're going to patch or seal something on a boat it's a good idea to use the right material for a long lasting repair. Polyester resin and fiberglass is what your boat is made of and what you should use for hull repairs.
scouser5
Re: flex seal
don't want to use it to stop leaks, just as a base cover , before painting transom
jigngrub
Re: flex seal
I wouldn't, I suspect a base coat of a soft material like that would lead to the top coat scratching very easily, if you could even get the top coat to bond to it.
smokeonthewater
Re: flex seal
The ONLY way I could see that junk being useful on a boat is if you cut a hole in the bottom and mounted a screen door there... THEN yeah use flex seal to coat the screen and go fishing..... but stay close to shore
