Float switch basic question
KBHumphrey
Not sure if this belonged here or in the engine area, so mods feel free to tow...
Replacing my float switch since there's a broken piece and it doesn't fire off automatically. Looking at the iBoats store, it's the Atwood model without a cover. Does the covered model provide any advantage?
Secondly, the switch was "floating" around, not fastened down, which seems like it would also prevent proper operation. There's a screw inserted in the bottom plate right near the pump. I'm assuming this was how the switch used to be secured?
Thanks in advance
Re: Float switch basic question
Thanks in advance
Ayuh,... The cover prevents debris from floating under, 'n jammin' it On...
Yes, it needs to be secured...
