Flywheel replacement on VP 4.3???
96 Wellcraft
Is there anything else that should be looked at why the shop is replacing the flywheel? I know a starter would be the obvious choice, but anything else? Thanks
Bt Doctur
Re: Flywheel replacement on VP 4.3???
Flywheel: cracked out of round,bad balance
Damaged ring gear: incorrect number of teeth on the bendix
hydrolick lock
loose starter bolts
most times you just replace the ring gear not the whole flywheel
96 Wellcraft
According to the shop the flywheel is missing teeth and would need replaced. It quoted 1200.00 for replacement.
