Flywheel Screwup - 50hp
John in WI
I admit it. I'm brain dead.
While replacing the trigger assembly on my '83 50 hp 4cyl., I removed the 8 center bolts and separated the flywheel from the center hub. Now I don't know how the keyway sits in relation to the timing marks on the outer edge of the wheel.
Can anyone help me put this back together properly?
John
Laddies
Banned
Re: Flywheel Screwup - 50hp
Stick a screwdriver in # 1` cyl and roll the engine to TDC then align the TDC mark
j_martin
You ain't brain dead. It takes brains to realize and admit a mistake.
Brain dead would throw it back on, then post a "I can't get no spark" thread.
John
John in WI
Thanks for the help!
On inspecting the flywheel, I see the number scale indicating degrees, but I don't see a specific TDC mark. Do I set the pointer at zero?
John
John in WI
Thanks for all the advice.
I've replaced the trigger and set the flywheel at 0 degrees with the #1 at TDC. The motor fired right up, but still runs rough- although much better than before the trigger replacement. All four cylinders are sparking and when at idle the motor runs at 5 degrees to the right of 0 (zero).
I moved the flywheel one bolt each way of the zero mark, but see no improvements in the "miss".
Should I continue to move further out on the bolt pattern or am I only risking damaging my engine?
John
You need to set the timing in accordance with the proper link and sync procedure. Moving the outer flywheel does not change the timing.
John in WI
The link and sync is next on my agenda. I just want to be sure I have the flywheel correct before I begin. From what I can tell, I'm at the correct BTDC position at idle speed. Now I need to fine tune. I tore into this one far too quickly and am paying the price.
John, The outer flywheel can only be installed in one of 8 ways. 360 degrees of rotation/8 is 45 degrees. So, if you install the flywheel incorrectly by one hole, your timing will read 45 degrees off. In other words, if you stick a screwdriver into the top cylinder, set the piston to TDC, and your timing is within +-44 degrees of TDC, you have the installed the outer flywheel correctly.
