Fm161 1985
Streetgang
Re: Fm161 1985
I will try to post pix of the progress. Got another package of boat stuff from ups today so, progress continues...........[/QUOTE]
Will look forward to seeing them.
Even at this age isnt it fun to see UPS show up with hard earned gifts !
train
Re: Fm161 1985
Well, I have gotten quite a bit done. Finally took some pix.
Happy with the vinyl........
Bent up a new transom cap
I bent the aluminum into c channel in a brake then bent the curve over the transom cut out with a slotted piece of plywood. It worked very well
jbcurt00
Re: Fm161 1985
Excellent work
Is that the transom cutoff that you used as a form to bend the C channel over? Great idea.
lmuss53
Re: Fm161 1985
Great looking rehab train, I wish I'd had you skills when I lost my transom cap last year. :) I haven't been here in a while, it's nice to see other Sea Nymphs on the forum.
Watermann
Re: Fm161 1985
Good job on the vinyl flooring. Nice thinking there on the new transom cap. Looks like out SN's are going to be the same beige color.
train
Re: Fm161 1985
Thanks guys. Funny, I dont remember everything in the mid eighties being shades of brown! SN sure seemed to like it.
train
Re: Fm161 1985
The new front battery box
Approximate location of charger and fuse block
Newly installed charger plug on side of console. Noco brand, seems of very good quality
And finally, the new switch panel mounted
Streetgang
Re: Fm161 1985
Wow,
Excellent work Train. I haven't seen a better fabbed cap on any thread and great ingenuity.
Your boat is outstanding and great job sticking with it.
Looks like will be watching a few S/N splashes here soon.
Thanks for sharing, a real pleasure to follow along.
jbcurt00
Re: Fm161 1985
I think SG ^^^ means HAVEN'T seen a better cap fab job :facepalm:
Pmccraney
Re: Fm161 1985
Wow! Very cool. For selfish reasons, I need more info on this process please!
Your work is crazy good!
train
Re: Fm161 1985
Thanks everybody but, using the plywood really does make this process quite simple and hard to screw up. For weeks off and on I would contemplate how I was going to bend this. I thought of different jigs, etc. that I think would work but, would require to much time and effort. Then the time came to do it. As I was walking to the fridge (for obvious reasons), I glanced at one of many piles of wood cutoffs. Then it hit me. One of those "Duh!" moments.
First figure your dimensions and cut your blank. I would suggest cutting too long and trimming after. Measure and mark your break points with an awl.
Now if you have access to a break , break into a channel. My aluminum was about .051. I would think this would be very hard on a siding/soffit break. I did mine on a steel break at work as my home break is only 4' wide.
Now find a scrap of plywood from your new deck or transom. Cut longitudinal slots on one side, slightly deeper than the c channel
Then flip the wood and cut muliple, closely spaced slots allmost all the way through, perpendicular to the previous two slots
Then, locate your transom cutoff.
center your channel on the cutoff, slip on the ply and, flex the ply to form
Maybe I got lucky but, my bends turned out flawlessly
I think the trick is to keep the two slots as tight as possible on the aluminum. I used a cordless circular saw because it has a thinner kerf than my other saws
jbcurt00
Re: Fm161 1985
Hmmm
Looks like I need to find a steel 6' break :facepalm:
Nice how to bend a transom cap tutorial, thanks
ezmobee
Re: Fm161 1985
Your vinyl work is top notch. Your transom cap even better. Great work. I'm sure we'll be sending people to this thread when they ask how to remake a transom cap.
train
Re: Fm161 1985
Thanks ezmobee! Thats very nice of you to say. The cap was surprisingly easy and, I love the vinyl! Very glad I went with it.
By the way, contact cement is (in my opinion) the way to go. I did both.
Watermann
Re: Fm161 1985
Hey Train it's been a month since your last post. Is everything alright there? You off fishing now?
train
Re: Fm161 1985
I'm still kicking guys! Had a rough couple weeks. My son lost his truck to a freight train a couple weeks ago. He's fine but, the truck.....not so much. He got his new one Monday so, I get mine back!
Got some stuff done on the boat, I'll try to get some pix up soon.
StreetG, your boat is coming along nicely, And Waterman, yours looks fantastic! Gotta get going on mine! plan to launch a week from Sat.
laurentide
Re: Fm161 1985
Man, I'm just seeing this thread for the first time. Amazing work. The transom cap fabrication is...just, wow. Great stuff.
Streetgang
Re: Fm161 1985
Train,
Hang in there my man
U have an invesmetnt and we all have lives
balance tne 2 and u will launch that beauty
u have supporters hanging on ur work cause u rock
standing by
