Foam installation ?
Mack-McVey
Is there a particular type of foam that is used on the inside of the hull ? The boat owner before me used what looks like the Great Stuff available at the Home Depot. Will that kind of foam insulation be acceptable as water-worthy ? I think he might have been trying to cover and seal up some cracks in the hull. There are a few places I can see daylight through small pin holes and thin spots. And other than working with a lot of fiberglass cloth and epoxy resins, is there an easier and better way to cover and reinforce the plywood in my boat ?
Yes, pictures will help us see what you are seeing.
As for the questions . . .
Yes, there is a particular foam that is supposed to be used inside the hull, and it is not Great Stuff. :eek: It is 2-part urethane foam that is USCG compliant.
Pictures will help us understand the rest of your questions.
flotation foam is 2-part
if someone sprayed expanding foam as a sealant, your boat has other issues
if you can see thru cracks and pin-holes, your boat does need to be properly repaired before you use it.
what are you working on, and what is the issue?
post pics
