? for bellows alpha 1 gen 2
riverboy460
how can i install the metal ring around bellows with out the driver tool i got the bellos sitting in the grove of the bell housing but cant figure how to get the metal ring on to hold it in place
wca_tim
Re: ? for bellows alpha 1 gen 2
you're talking about the large "hose" clamp, right? have you got a manual? You'll need to glue it on with bellows adhesive with the clamp in place and have the clamp positioned so you can tighten it with a screwdriver or 1/4 inch ratchet with a long extension. not necessarily a trivial thing based on my experience, but it gets easier...
xltier
i got mine in one time with a little armor all on the ring and pushed it in with a piece of wood.being careful and making sure it was in all the way.then i heated it with a hair dryer to dry the armor-all and it was set good.
riverboy460
no i have the bellows boot atached to the back of the boat already at the gimbal bering side. the side that attaches to the bellhousing and outdrive side dose not use a hose clamp on the gen 2 it has a little metal ring u have to drive in with a seal driver i dont have one that big neither dose autozone rent a tool. im stumped cant get it on the water till thats done. iim clueless how to do it.
Bt Doctur
Try a plumbing store for a fitting, cap, sleeve, sched 80 pipe etc.
riverboy460
ya i tried a 4vinch piece of abs too large fr opening in bellhousing bummer
