Force 115HP head torque specs
tazameir
Hello, <br /> Does anyone have the torque specs for the head bolts for a 1986 115 HP Force outboard? I'm ordering a manual, but would like to get my head back on this weekend.. Thanks!<br /><br />C.
tazameir
Re: Force 115HP head torque specs
Looks like no one has a book handy. I'll post what I find when my book arrives in the mail.
hamburgerman
my book shows no force 115 hp. I have the book 4-150 hp. 84-99 includes l drives I need more info
If you have an 1986 125hp, then torque spec is 225 in lbs.
Frank Acampora
225 inch pounds in a spiral pattern from the center two bolts out. Torque in two or three steps. (for example: 150, 200, 225). If it is a new head gasket, re-torque after about 1/2 hour running. No need to re-torque a used gasket--it will not compress any more under heat
