Force 150 compression ???
yert
We had compresion numbers ran & they where 120- 110?? is this good?
Re: Force 150 compression ???
Good enough.
They were about 145+/- when the engine was new.
Was the engine warm when you tested it?
You will get higher numbers on a warm engine.
yert
I dont know wasn't present at time of test. It a J type engine. Is that better or worse then other models of 150's?
J is no different than the others. Likely that some component was bought from a different supplier, so they gave it a different production letter.
yert
thanks again, will test tomorrow....
