force 85 broken bolt with water coming out
jerryjerry05
If you've removed anything else?
Make sure you seal it good.
The exhaust port covers, new gaskets still leak and cause problems.
74bayliner
jerryjerry05 how do i ensure the seal it good. Do i cover the gaskets with something if so what? I have seen evinrude repair videos where they use a evinrude brand gasket sealer, i do have some of that do you think that would work to cover the gaskets with that?
jerryjerry05
That's exactly what I use.
OMC's gasket sealer.
Expensive but great stuff.
For some reason?? I ALWAYS spill at least 1/2 can of the stuff ??
Make a mess and then cry about loosing $ :)
74bayliner
jerryjerry05 do i still put that stuff on the head gasket as well? I was told if the head gasket has some sort of a coating on it, than to not put that stuff on there. But it makes sense that i would. Thanks your for your help. Tremendously. Everyone!
Waiting on those gaskets cant wait to get this back together.
jerryjerry05
No gunk needed on the new gasket.
But you can save 35$ by using sillycone on a good gasket
If the old gasket is all there? silicone will work if the glue is melted off and you need to reuse
the old gasket.
74bayliner
oh ok. Understandable. I didnt take that into consideration as i tore into it. So thats ok. Next outboard i do though i will remember.
