Force L-drive U-joint specs
Kwasy Wabbit
Hello,
Does anyone have specs on for the U-Joint for a 125 hp L-Drive (reserve the non-constructive comments, I?ve heard them all). I would like to know if anyone has found a replacement / aftermarket part for this crazy over priced part?
If any one has spec?d out this part I would like to get the measurements from them so I might be able to find a compatible replacement. I don?t have my u-joint at all so I can?t throw a set of callipers on it to get the specs.
If some one has spent the time measuring this part or is willing to I would be a great help.
I searched through several pages of forums and did not see the answer i was looking for. If it is previously posted I apologise and would appreciate it if someone can direct me to that post.
Re: Force L-drive U-joint specs
I would go after this one with a vengeance.
Even if it didn't fit for some reason, you would have something to work with and to measure.
Only 6 hours left.
Force l drive u-joint | eBay
