Force model 152F7A???
bowlin257
I can't find this model listed anyplace for parts. Need a carb rebuild kit and possible a needle valve and float. The carb is stamped "LMB", will another year carb work?
Re: Force model 152F7A???
Your motor is a 1987 "A" model
The carb repair kit is available from Mercury for $18, part number FK10123
The gasket kit is part number FK10124 , $4, which may be included in the repair kit, ask when ordering.
The float is part number 1395-5898 , $15
THe needle is number F10077, $6
Refer to these 2 links for a part diagram:
http://www.mercruiserparts.com/Show...c=CARBURETOR+(9.9+&+15)+(84A+THRU+87A+MODELS)
Don't order them from that website though, as they have a huge minimum order surcharge.
Try dougrussell.com , or your local Mercury dealer.
