Ford Ranger question
dancudayo
I have a 98 Ford Ranger, recently something like a collar on the output shaft before the U-joints, transmission side, has spun loose, It looks like an easy repair, but my Haynes manual talks nothing of this piece. I think it is some kind of balancer. It seems to be secured on by some kind of sealant and force fitted. Does anyone know what this thing is called? I only noticed it cause when turning corners the weight transfer makes it clang and clunk and it also gets spun about from drive shaft turning. I wired it up away from moving parts, cause my auto parts store doesn't sell drive line components so I either have to get it from a junkyard or ford dealership. It's not a 4wd, I hope someone can tell me what its called and what its for. If you need more detail I will do my best to describe it more, thanks everyone! Dan
mrfixitman40
Re: Ford Ranger question
the piece you are looking for is part of the front yoke .
Kenneth Brown
I agree. I also agree you are correct in your calling it a balancer of some sort. It is supposed to cancel out high rpm frequencies that will make a vibration. Ford has tons of fixes for there cars/trucks and this is only one of them. I always wondered why they didn't just get rid of the actual problem instead of bandaiding it.
Caveman Charlie
If you have a junkyard in your area that will let you crawl under some other rangers and look. Then maybe you can find another one and get a idea of what it should look like. I'm guessing from your description that it is some sort of balancer just to make things more smooth. I bet you don't even need it.
I have seen them removed with little effect. I know someone that was trying to cure a vibration problem and removed it. Went as far to have a new one installed and still had the same problem. Pull it off and try it.
dancudayo
thanks everyone for your help! Yah, it really doesn't seem to be a necessity cause I've been riding around for a few days with it just wired up out of the way, lol. I plan to remove it but today on my day off just got some work done on my project boat. All though it might not affect anything now, I still worry that it might be some kind of balancer that protects the transmission or something. So, I guess I'm going to hit a junk yard very soon!
SpinnerBait_Nut
Call your local Ford dealer and ask them what it is.
mrfixitman40
It is meant to remove harmonics from the drivetrain could eventually cause the bushing in the trans to wear out. wouldn't worry to much about it unless you do alot of highway driving. I would definately remove it soon though since it could cause more damage with it being out of place.
dolluper
I've read this a few times and it sounds like it is the output shaft seal lock to me but what do I know without seeing it
