forgot my torque wrench
dkellogg3
Down at the marina pulling risers to check them and the exhaust shutters. Forgot my torque wrench at home. Necessary, or can i do it by feel?
nola mike
Re: forgot my torque wrench
Better to use, but I'd be willing to bet you wouldn't be the first to do without...
ziggy
if it were me, i'd go home and get it...
i prefer using a torque wrench. if at all possible.
yep, i reckon that's very true... and after saying what i said. i'll fess up and say i've done w/o too... guess in the op's case, the question is, how far away is home?
Ayuh,.... I use my calibrated elbow,... standard 3/8" bolt torques are pretty common, 'n the elbow knows...
I would say if you have to ask, you probably should get the torque wrench.
Some may use the "calibrated elbow" method but they usually do a lot of wrench turning and know how tight tight they are getting bolts and more so how even from one to the other they are tightening bolts.
And I would bet Bond-o picks up a wrench more than to work on his boat engine once in a while.
Ayuh,.... Atleast Daily,..... Most days, All day.... ;)
minuteman62-64
I'm no mechanic, and only have a semi-calibrated elbow - but I'd take my best shot at tighting the bolts at the marina and then torque them correctly when I got home. Unless you commonly drive around with a torque wrench its not much diffenrent than what you do when you fix a flat out on the road.
NHGuy
Well do 30 foot pounds then!
I'd take my best shot at tighting the bolts at the marina and then torque them correctly when I got home. .
Not a good idea, if your semi-calibrated elbow over torques the bolts, then you go back and re-torque it with a torque wrench you could have less torque. Now you have a leaky gasket. If you torque it without a torque wrench, and it doesn't leak, leave it alone.
To properly re-torque any bolt, you loosen first then re-torque, you don't just put the wrench on it and pull 'till it clicks.
dkellogg3
I went back. The extra 12 minutes was worth the peace of mind.
dkellogg3
Its the bendy kind. Not sure that those get calibrated...
