forward propulsion went to almost zero last run out this summer.
ferettfett
I took my boat out in sept for my last day of wakeboarding and towards the end of the day my forward movement went to almost nothing. the shop said the transmission and engine seem fine and that maybe some plates inside were dirty. suppossed to bring it back in the spring. does this sound normal or should i be alarmed? the boat is a 1995 moomba sk with a 351 motor.
Re: forward propulsion went to almost zero last run out this summer.
Plates were dirty? I don't think so, check fluid level and may find it low and the clutch plates may have burned. Either pump is week, filter is clogged or tranny needs a rebuild
ferettfett
the fluid level was good, no debri or grittyness in it. how do i check the filter and/or pump?
ferettfett
if i remember correctly, it was damper plate or flex plate the shop mentioned that might be the issue
southkogs
Prop go sour on ya'?
ferettfett
not sure. this is my first boat. it ran like a champ all day. last run it just went forward really slow. motor reved up just like normal.
southkogs
Moomba is a direct drive, right? I don't know how props work on those (never dealt with it), but my first thought would be a spun hip on a I/O or Outboard.
Ayuh,... Welcome Aboard,... You say it's got a 351 Ford motor,..?? Who's Name is on it,..??
What transmission is mounted to the motor,..??
It's an actual Inboard ain't it,..??
I'm wonderin' why ya posted in the OMC forum,....
ferettfett
It is a direct drive.
ferettfett
It is ford block with a PCM transmission.
Sounds like you need to pull the transmission. Before that check the trans fluid level cold. If it's low need to add some and find out what leaked. If it is discolored and smells burnt then the clutch pack has burned and trans needs rebuilt.
Edit: Check connections on the oil cooler
lx.crowell
I would check the prop because on the direct drive boats there is a key way on the shaft that locks the prop to the shaft,my guess is that the key way broke from use. There is a nut on the end of the shaft, take that off, then remove the prop, you'll probably need a prop puller, and the key way is on the inside of the prop.
