free AQ120B carb base gasket(s)
dgabler
Bought a roll of 1/32" gasket material in the event I needed to replace my carb base gasket (where it mates to the manifold). Was not about to spend freaking $8 for another "oem volvo" gasket when I could make my own!!!
Have a few traced gaskets up for grabs. If you want one send me a PM and I will give you my address to send a SASE to. I will mail you a traced gasket.
No charge unless you want to cough up a whopping $0.20 for material.
Note: This is for a Solex 44 PHN, AQ120B .
captmello
Re: free AQ120B carb base gasket(s)
My friend, if you get worked up about spending $8 on a part, you may want to get a different hobby.:eek:
I made a couple gaskets for my old tractor this spring. Good Work!!:)
