From idle to WOT
Eazzy
Need a brain refresher when taking off from slow idle 1000 to WOT carb loads up a little but then takes off ok do i turn the jet screw in or out it is set at 1 turn out now. 1996 75 Force with single carb. Read setting before on here can't seem to find it now Thanks
"B"
Re: From idle to WOT
I think the setting is 1 and 1/8 but that would make your mixture more fuel rich. Perhaps your issue is timing and not fuel related. Or, it could be your exhaust ports are carbon clogged. Maybe try a de-carb process see if that helps. Good luck.....
spool
Read this
http://forums.iboats.com/showthread.php?t=431021
"8B. Now go the opposite direction. Adjust until the engine runs rough, burbles, or stalls. Note this setting.
8C. Set all needles to the average between the two settings: That is, for example, if it stalled at 3/4 turn out and burbled at 1 1/4 out then set all needles to 1 turn out.
8D. Readjust idle speed to 700-750 RPM.
9. Take the boat out on the water and do a "hole shot"--Full throttle acceleration from a stop. If the engine "sags" then recovers and picks-up it is too lean. Open the needles about 1/16 turn at a time until the engine accelerates with no hesitation.
If the engine sputters or coughs or burbles, then clears itself and accelerates, it is too rich. Close the needles about 1/16 turn at a time until the engine accelerates smoothly."
A slight stumble before acceleration is good. And also expected it you have been idling for a while.
Instant acceleration is usually a little too lean.
Jiggz
Usually, with hesitation for shot out of the hole means adjusting air screw out or CCW. Experiment turning the air screw out 1/8 of a turn each time and see where you are satisfied. You don't want to go above 1 1/4 turn out for this will result in too rich of a mixture fouling the plugs. On the other extreme you also don't want to go below 7/8 of a turn in due too lean of a mixture causing piston and cylinder damage.
Eazzy
Thanks guy's had a brain fart glad youall are here to keep me straight.
