Front Motor Mount Replacement - 1987 120HP
canufixit
HI,<br /><br />I see that my forn mount has sagged and I'm planning on replacing the front motor mount... After I support the engine and remove the mounting cross arm - I think the mount is pressed in ??? My motor / mount is clean an not rusty aor anything ... I have a smapp hyd press - is this going to be the repair from hell - or will this mount just tap out wiht a hammer ??<br /><br />Thanks all for the help - Love the board !!!<br /><br />SteveC
Re: Front Motor Mount Replacement - 1987 120HP
I think You're Right,.........<br /><br />That rubber bushing is Pressed into the motor mount,...........<br /><br />It'll probably be Cheaper,+ Easier to pick up a used Mount on ebay.........<br /><br />Don't forget to pull the outdrive,+ Realign the coupler + Gimbel bearing, after you replace the mount..........
