frozen locks
dhud64
Every year we have problems with frozen padlocks.<br /><br />We have tried graphite and it works fine for a while. We generally end up carrying propane torches in our work vehicles to thaw locks at various locations. Obviously this only makes the problem worse!<br /><br />I need a better solution. I need my guys to be able to get into the gates at work before we even start worrying about torches. Most guys don't want to carry propane torches around in their personal vehicles, or that would solve it, sort of....<br /><br />Is there somethng that wont freeze if left outdoors, that can be used to thaw locks? Maybe this something could be protected in some kind of enclosure thats insulated...?<br /><br />Any ideas?
Pony
Re: frozen locks
have you tried lock de-icer.....It usually comes in a sryinge type thing, and you insert it into the lock and squeeze some in. We used to use it for trailers we kept outside to store merchandise for christmas.
Pony
Re: frozen locks
you can carry it in you pocket very very easily. no biggie
SS MAYFLOAT
Re: frozen locks
I get the same problem on our stores roof ladders. I heat up the locks to get all the moisture dried up in them. Then I soak them in some oil for awhile. Let them sit and drain, wipe off the excess. Then I'll put just a bit of grease around the shank and inside the lock where it latches down. This helps keep out the rain water. I do this prior to each winter and have pretty good luck with them not freezing up.<br /><br />It is a must to get any moisture out before lubing them up.
SlowlySinking
Re: frozen locks
I saw this 50 years ago in northern NY at a Texaco storage yard. They used a large tin can and cut 2 holes in the bottom for the ends of the chain, the lock goes inside the can and the setup hangs down with the lock out of the weather, this <br />keeps most of the rain/snow off the lock. It worked for them. Heavy duty plastic would probably work as well and no rust, good luck.
dhud64
Re: frozen locks
Originally posted by SlowlySinking:<br /> I saw this 50 years ago in northern NY at a Texaco storage yard. They used a large tin can and cut 2 holes in the bottom for the ends of the chain, the lock goes inside the can and the setup hangs down with the lock out of the weather, this <br />keeps most of the rain/snow off the lock. It worked for them. Heavy duty plastic would probably work as well and no rust, good luck.
Now that's original, I like it!<br />That will work for about half of my locks. The other half actuall, slip through a small hole on the gate latch.<br /><br />Thanks!
Re: frozen locks
I've found that Spraying them Full of a Spraycan Grease keeps them from Freezing.........<br />A Couple times a year keeps them working Smoothly All year long........ ;)
CalicoKid
Re: frozen locks
I've been using silicone spray with good results.
