fuel assortment of ?
does anybody know what difference a 82 style fuel pump on a '78 115 might make? also is there any correlation between johnson jet sizes( 54c for example) and orifice diameter (54c=.054)? this one is not fuel related but are resistor wires for the plugs ok? napa says sure boat dealer is along ways off and I thought I read somewhere that it's not good but I can't remember if that was suppresion or resistor. thanks alot odd questions from a bored mind (can't wait to fix the boat,camper and tukey hunt so I can fish.
rwise
Re: fuel assortment of ?
unless your manual says otherwise, use only real copper wire for the plugs. it makes a differance. there are posts that explain it.<br />Richard
Your Napa guy is wrong. Only use wire core sparkplug wires. Too much resistance in the fancy auto wires. They can damage your coils and cd unit/switchbox.<br /><br />By the way, Napa carries a complete line of marine parts, including plug wires. Funny he didn't know that.<br /><br />You should be able to get a set of plug wires made up at any small engine repair shop, and at a full service auto parts store.
