fuel consumption / engine efficiency
QC
Re: fuel consumption / engine efficiency
richmllr,<br /><br />I think it is reasonable considering the weight comment. I get around 3.3 but my 23' is probably lighter and MPI.<br /><br />
BillP
Originally posted by richmllr:<br /> As a related issue, how long (minutes) could I safely run the GM 350 at WTO without damaging the engine, assuming that the oil is what it should be and the cooling system is operating properly? I earlier said that the max rpm was 4400 rpm. Actually I think it is closer to 4600. Thanks for your comments.
Approx 120,000.<br /><br /> :D :D :D
Texasmark
Just a tidbit. Mercruiser uses GM and Ford engine blocks. Most everything else is Mercury. Designed and built to run hard whereas the car-truck that the automotive mfgr used the engine in only ran in the lower thousands of rpm's....like you run your boat at 3500 to 4500 (or whatever) for your trip whereas your road vehicle is sitting on 2000 at 70 mph.<br /><br />Agree on the importance of oil. If it were perfect, there would be no friction. No friction means no heat, no wear. Engines would last a lifetime.<br /><br />My 2c<br /><br />Mark
