Fuel Filter/Water Separator for 1990 Force 90
Derrick Fronckowiak
All, I was thinking about getting a fuel filter/water separator for my 1990 Force 90. I think I'm getting condensation in my fuel tank (can't always keep it full) and want to keep the water out to help prevent corrosion. Any recommendations as to which brand and model of fuel filter/water separator I should get?
For the most part it really doesn't matter. Suggest the cheapest filter head and a 10 micron filter
jerryjerry05
Wal-mart is a quick pick.
Look on e-bay for cheaper.
While you adding a filter, get one for between the pump and the carb.
Fram G-2 G-3 G-12.one of these will work.
This is a fine particle filter and helps keep the carb clean.
Install the bigger close to the motor as possible.
The newer fuel break down in the lines and this catches the water before it hits the motor.
