Fuel in the water..
JARB
I recently bougt a small 14' boat with a 1996 Yamaha 30 ESRU 2-stroke motor. It was running a bit rough at idle, spitting and stalling and fuel could be seen in the water at idle. At speed she ran good.
I dissambled the carburetors, cleaned them in an ultrasonic washing macine so they are absoletely clean. Installed a repair kit and since the idle needles were quite worn at the middle and lower carb I replaced them as well. To be perfectly sure everything was in order i also replaced the low speed fuel jets although they looked OK. The low speed air jets cannot be bougt as spare but they looks perfect.
The carbs have been synced and adjusted according to the repair manual. I have installed new gaskets and diaphragm in the fuel pump, new thermostat, new sparkplugs and checked compression - 135 on all three cylinders.
The engine now runs perfect, normal 2-stroke smoke. I can idle for half an hour and then just slam the throttle lever to the bottom and she responds immediately without any hesitation all the way to WOT at 5400 rpm - But still sometimes gas in the water at idle.
The engine is a short shaft and the boat has a rather deep Vee for this size of boat so the engine sits low on the transom. I have now noticed that fuel in the water only shows up when the exhaust relief ports becomes submerged, as long as they are above the water - No gas in the water.
Is there any guidelines for the engine height and should the ports always be above water? Or is my symptoms indications of something else not beeing right with my engine?
99yam40
Re: Fuel in the water..
sounds like you have covered all the basics and if the motor is running fine I would not worry too much about a little oil residue on the water. Run it for some time and see if it clears up as there is some residue in the exhaust that will have to burn away from the problems you had before.
the idle exhaust relief holes are there to relieve the back pressure while idling and they should be above the water. If it just dips down below the water from time to time it should be OK, but they should not be under water all the time
robert graham
If your carb floats are set right and your fuel pump diaphragm is new, then it's probably just some oil and unburned fuel that is normal for a 2 stroke motor to discharge through the exhaust. Is your motor oil injected or premix?...Maybe try the Pennzoil 100% Synthetic Outboard Oil for less smoke and carbon? What you describe sounds pretty normal to me.:)
