Fuel leaking between case halves
Any more information ?-----Possibly the bypass covers leaking ??.-------Was the motor apart ?
Flipsy
Dunno, the shop just told me that fuel was leaking between the halves, and it would need to be resealed. They said they currently don’t have time for such repairs because the are behind due to the flooding this summer.
It is rare for the joint to leak.----Perhaps check the bolts on the bypass covers.-----6 bypass covers and 6 small bolts for each cover.-----Cheap gaskets and easy to do yourself.
Flipsy
my dad had the engine overhauled, we did the break in on it for him. Then he let it sit for 9 years. Just picked it up from the shop, the guy was quick to offer me 500 on trade for a used outboard. Kinda has me thinking. Pretty sure he seen all the new parts when they took the cowl off 🤔
Flipsy
I am, got em ordered. Needed a fuel pump too, going to get rid of the VRO and mix my own fuel
Bosunsmate
If you can see where its leaking you may as well try and cover the outside with sealant as its leaking air in which will really do the damage
