Fuel Line Sources
stouchton
I want to replace the fuel lines on my 4.3GXI-E's. They are 20 years old, and I do not know how long they truly last. Is Volvo Penta the only source for these lines?
Which lines?
the lines from the fuel fill to the tank is an A2-15 rated hose available anywhere that caries it
the lines from the fuel tank to the filter head are A1-15 rated hosed available anywhere that caries it.
if you are talking pre-terminated engine side hoses between the fuel pump and fuel logs, then yes, those are Volvo Penta only. However there are hose shops that can make appropriate MPI low permeation rated fuel hoses
stouchton
Thank you and sorry I should have specified. I was asking about the engine side hoses (to and from fuel pump).
