Fuel mux for 1960 Evinrude 10HP
N2outboards
Please can someone give me the correct fuel mixture with my particular model in image ive shown...1960 Evinrude Sportwin 10hp
The original mix was 24:1------But today you will get many different opinions as to what will be proper lubrication for that fine motor.----As previously indicated to you it has a bronze bushing ( if still original ) on the wrist pin.----And that is a known weak point !
N2outboards
Then would a 50:1 mix be a much richer fuel mix over a 24:1?...could it explain why i've been getting a bit more blueish/ grey smoke using a 50:1 mix since ive ownd the motor and 1970 12ft. Valco for last twelve years...even when ive used a 50:1 mix with my outboard mux knobs more toward 3/4 lean still witnessing more of exhaust smoke.Mayve i'll try the 24:1 method, just was worried of running to lean thereby a fried powerhead.
50:1 is approx 2% Oil, 24:1 would be 4% oil. So depending how one looks at it, either could be called Richer. A 24:1 mix would be Richer in Oil(double), but 50:1 would actually be a bit Richer in Gasoline, 98% vs. 96%
If the engine has any Friction Bearings(Bushing), then 24:1 is the safer Option
Need to review your math.-----24:1 is more oil than 50:1.-----Need to understand the concept of why oil is mixed with gas.----Need to understand the concept of lubrication in a 2 stroke engine !!
flashback
If it were mine I would run the 24/1 mix and enjoy the smell.. I actually do like it...:)
oldboat1
Don't confuse the gas to oil ratio with air mix (air to fuel). Run with the factory-specified gas/oil ratio, and adjust the air mix as lean (fuel) as required for smooth running. The engine will tell you if it is too lean (backfire at the shaft outlet -- "lean sneeze") -- or stalling.
I still remember the Sweet Aroma of burnt TCW Oil. An added Bonus is, it keeps the Skeeters/Horseflies at Bay.
N2outboards
Ok. Thank You all of you so much.
