Fuel oil mix ratio?
AcousticTX
Hi all, <br /><br />I know this is a dumb question..but.. I just purchased an old boat, and want to make sure I get the fuel/oil mix right. My motor is a 78' Johnson 70hp. Does anyone know the correct ratio?
Spidybot
Re: Fuel oil mix ratio?
A search on these forums would have told you numerous times, that it's 50:1<br /><br />Even look here
Spidybot
Thnx, friend.<br /><br />This forum is an almost unlimited collection of info and it's available to all by the search. If you do not find what you look for, put a new topic up and folks will help.
V156
To be sure you have the correct 50:1 mix you can go to walmart and get a mixing bottle in the fishing dept for $2.<br /><br />Dutch
50:1 = 1 pint (16 oz) or quality TCW-3 two stroke oil mixed with 6 gallons of regular (86-87 octane) gas. <br /><br />Don't bother with high test it will lead to early carbon build up and not deliver any extra performance.<br /><br />Bob
