fuel problem 15hp Force ????
trueturn
92 Force 15hp installed my new aftermarket ignition pump it up choke it fires right up runs and dies plugs are dry so it's not flooding would this be a fuel pump problem what else should I look for I did order a kit for the fuel pump could it be my tank also you pump it up hard and when it does die the ball is soft it should be simple wouldn't you think any sugestions before I wig out I got too many hours in this thing good thing I didn't have to pay the man LOL
Re: fuel problem 15hp Force ????
If the bulb is going flat or very soft, it is the fuel pump that is sucking it flat. Blockage would be in the fuel line or tank, or the tank vent is closed.
