Fuel Quantity Indication?
Duckbay
We've had a used 150 S/W II Yamaha installed on a 20' Grady. The Speedo has a fuel gauge as well and so the Techs disconnected the old standard gauge and went with the Yamaha gauge.<br /><br />The question is, can I connect both fuel gauges in parallel, off one sender? The Yamaha gauge doesn't appear to be all that accurate, perhaps a compatibility problem?<br /><br />Thank you!
Re: Fuel Quantity Indication?
Rarely will you find a reliable guage for fuel. Some people with built in tanks use a wooden dowl to confirm the guage by dipping it in the tank.<br /><br />Bob
sproz
Hi,is the sender correct for the guage? I've just replaced my fuel guage on my bayliner and had to make sure I got a guage suitable for a U.S. sender as standard senders in the U.K. are apparantly different. Just a thought.
