fuel rail???/pump
twin40
I was just wondering if my 68 big twin 40hp has a fuel pump.
Also i am missing a tube the comes off of the carb and goes back to the cylinders i will post pics later tonight. Thanks in advance.
-Bobby
tashasdaddy
Re: fuel rail???/pump
68 does have a fuel pump, follow the fuel line from the connector, to the pump. picture will help on the others
twin40
Thanks for the quick reply
Does anyone know the part number by chance for the fuel pump??
Willyclay
Bombardier still has parts listings for 1968 motors but you will probably need to know the specific model number unless fuel pumps were generic for all. Once equipped with that part number, a local dealer can work through the superceded numbers to find what you need. An alternate source for parts is Sierra Marine Parts at www.sierramarine.com. BRP parts can be accessed through www.evinrude.com. Good luck!
ezeke
The pump for your engine is 438556, which is available from your J/E dealer.
The Sierra aftermarket pump is 18-7352.
