Fuel Regulator cross ref or sub numbers
fbriggs
Can anyone tell me if there is another fuel regulator that will fit the 30-60hp 4stroke motors.
Merc pt# 892267A50. Merc not available till mid July boating season half over by then.
Or even a good used marine store that may have either the regulator or a complete VST.
Thanks
flyingscott
I don't know why you can't get it. I looked up the part online and found at least 2 of them
fbriggs
I don't believe you are looking up a 892267A50. If it crosses and you find one get back with where you found. I'll pay top dollar because every Merc dealer I've called said mid July. If you try to order non oem ( which I'm fine with) on a different site I can guarantee when you go to check out it will say they will ship within a period ONCE THE PROCESSING IS DONE. THAT MEANS ONCE MERC START TO PRODUCE MORE. This is the same thing Chevy trucks went through with truck chips. 6 month wait. But please if you can prove me wrong I will apologize but I think you will find NA til mid July.
