fuel starter valve 1998 dt 100 suzuki,,
phone sails
can my motor run without one ,,i have been spraying a little starter fluid for cold starts then she runs allday ,,or will this mess my motor up ,,that part was stolen along with the oil tank while i was on vacation,,
99yam40
Re: fuel starter valve 1998 dt 100 suzuki,,
not sure what a fuel starter valve is, could you be talking about the primer bulb on the fuel line?
It is never a good idea to spay either into a 2 stroke as there is no lubrication for the motor
robert graham
You could mix up some gasoline and some 2 stroke oil(50:1) in a spray bottle and use that to spray in your carbs to start your motor since your choke/enrichening device was stolen...might be better than the straight ether with no lubricant in it. Good Luck!:)
