fuel tank capacity 98 bayliner 2050 with 5.7l
Re: fuel tank capacity 98 bayliner 2050 with 5.7l
You might have to take a look below to see if you can get a glimpse at the certification label that is on the tank. That will have the capacity in gallons.
89sandman
the reason i know is it came with an almost full tank and we did run out of gas just as we were heading to the dock to load up the first time we took it out:)
scott8058
If you go to bayliner's website you can download a manual for your boat and it will tell you how big it is. I have a 95 2050ss and it has a 34 gallon tank. And btw you must be running it an awful lot to burn 25 gallons in a day!
