Fuel tank removal/ inspection questions 67 glastron crestflite.
liquidlabfx
Has ANYONE removed or inspected their fuel tank on this or similar models? Location of the fuel cell? Removal instructions etc? Appreciate the advise. I/O original setup.
That is a pretty obscure model here in 2024. You might trace the fuel fill hose and fuel lines to the fuel tank. If that boat has spent any time in saltwater and has an aluminum or steel tank, which is likely, I expect it to be in bad shape.
Most tanks back in '67 were steel.
