matt167
- Joined
- Sep 27, 2012
- Messages
- 4,394
I ordered a new OEM mercruiser fuel water separator to install in my boat after I had a pretty severe water in fuel issue ( cut trip short when kicker quit )
My boat has 2 fuel tanks with a selector. Should I keep the selector in place or tie the tanks into the 2 inlets together? I’m also going to hook the kicker motor into the separator as I think it’s actually a better solution on my boat. The kicker tanks only place is strapped to the transom which works but it also easily allows rain water in. I’m thinking I should leave the selector as that makes 2 separate fuel systems
Can I plumb a ball on the outside of the transom to the kicker? Obviously using marine rated fuel line
